Hi.
How do I remove the few danfoss ra2000 valves , 1985 models from my radiators. I tried unscrewing the valves and i tried with Allen key in the small hole in the valve but no luck.
Pic beneath. Thanks
I would guess that the grub screw is just a locking mechanism and that once it is loosened you unscrew the black ribbed 'nut' from the valve itself. You might need some grips to help loosen it if it hasn't been touched in a long time.
Thank u for ur reply.
i dont know where that grub screw is located. i tried to loosen the valve from the ribbed space in it but i could only manage to turn it around less than a 1\10 of a cricle then i tried to pull the valve out with no luck!
any ideas?
thank u but i didnt understand much of what u wrote, sorry for my bad english.
undo the grob....whats a grob and how do i undo it...i cant undo anything at the moment.
thank for ur patience
