removal of storage heaters
12 Mar 2007
Tyne and Wear
I removed 3 storage heater, removing the bricks 1st before taking them off the wall, is it posible to replace the switches on wall with a single socket?. Or will i have to use blanks . [/code]
Storage heaters are normally only powered during the night, so you would need an electrician to reconfigure your storage heater fuse box to be powered all the time.
Also all 13A sockets require RCD protection, which it's likely your storage heater supplies will not provide.
Indeed, and often it is in less than brilliant condition. Best to keep it closed until you know otherwise.
