Hi all, after a bit of advice...
I've just removed a breeze block wall in our 1930s semi that separated the toilet and main bathroom. The idea now is to remove the second door (pictured to the right below) and put a stud wall in it's place.
The question I have is what is the best way to remove the rest of the concrete blocks between the two red lines below as they are all 'tied' into the rest of the house. I.e. above the door to the right is connected to the bedroom wall which is also concrete blocks. Is the best way to cut (angle grinder?) along and then remove?
The same applies to the remaining bit of wall above the door to the left (which we're keeping) - if I essentially cut along the red line, will the door be ok with the remaining concrete left above it?
Hope this all makes sense and thanks in advance.
