I am trying to take apart my phone, and have 3 stuck screws.
They are very small screws.. 1 millimeter (mm) at the very most, maybe even a bit smaller.
(1) I used lubricant to remove some, but it didn't work on these 3 screws.
(2) I hit them with a hammer but it didn't work on these 3 screws.
(3) Pliers don't work because the screw is stuck in, and not sticking out.
The only remaining options I've seen are
(4) Screw extractor
The problem with this, is that there are apparently no screw extractors small enough for these screws.
I may be wrong on that though, so let me know
(5) Dremel
I fear as if this is going to cut all the phone plastic and stuff surrounding the screws, and therefore damage the phone.
What do you think..?? What is the solution here..?
(4) Screw extractor
(5) Dremel
