Hello fellow members
I have really been struggling with a new house purchase - The shower and sink and toilet are out and the kitchen is stripped bare so I am doing all the pipework from scratch.
I have a vented cylinder for hot water which will stay - In the loft is a cold water tank which is massive and pipes coming out to the taps.
I am thinking of teeing into the cold water mains vertical pipe and using that for all cold water sinks and toilet - Is that a problem?? I know I cannot remove the tank as cylinder needs to be gravity fed so am I correct that the only thing the tank will feed is the hot water cylinder and that is it? If true I can also replace the tank with a plastic one as the one there is extremely old!.
Was going to use 22mm copper pipe from the blue plastic mains water into the house and then tee off that for sinks and power shower - Anything to be extra careful of? My mains water pressure is 3 bar and 13litres a minute so decent!
