Hi
I'm looking for some help on the best way to remove my floor boards without damaging them so I can replace them afterwards.
It's a relatively new house with plasterboard walls and the floor is slabs of chipboard nailed into the joists.
I want to remove a small area of floor in our 1st-floor bedroom so I can route some cable from the loft down to the ground floor.
Is there a way to do this without causing damage?
I've drilled a few small pilot holes to check what's under the floor and it would appear to be a void - i was able to stick a flexi-rod through the hole and contact the plasterboard ceiling below.
Cheers for any help!
