That’s just a render base, its normal & still best IMO & many others. There is no problem with old plaster as long as it's basically sound.The walls in the house have very old plaster on by the looks of it a cement backing.
Are you sure it needs to be removed? If it’s not blown & in poor condition, you’re just creating unnecessary work by removing it all; a largely sound base can be repaired & re-plastered. If it is shot, as I said, just be careful how you remove it & be mindful of getting caught out by the regulations.Would just like to get it back as far as i can to get new plaster on.
You only need to cut away & remove what is in poor condition & take care of any deep seated cracks in the render base & sometimes in the blocks/bricks themselves; without popper reinforced repair the cracks will open up again. I carry out this sort of repair all the time in the renovation work do.Someone else said today why not skim the good walls rather than take all the old plaster off.
Of course it’s not cheating; there is absolutely no point in removing sound render & plaster; tap it with a metal scraper, unless it sounds hollow or is not physically crumbling it’s fine. Even if the surface looks uneven & rough from years of decorating & DIY hole drilling/filling, as long as it’s basically sound it can be made to look like new; once it’s been repaired & re-skimmed you would never tell the difference. Choose your plasterer carefully though, they need to know what they are doing with render/block repairs & you will need someone more experienced than a “board skimmer”. It won’t be cheap but it won’t be as time consuming or expensive as removing the lot & starting again.Think i will have a good look and only remove what looks and sounds poor.
I guess it would save lots of work, although i feel skimming is cheating a bit.
