Remove the Lever from a single lever mixer tap.
23 Jul 2010
Essex
Hello,
Can anyone advise me please? I have a - Reginox Zambesi Single Lever Mixer Tap.
This is leaking slightly, above the sink top.
Underneath the Lever is a small plastic plug which I removed expecting to find a locking screw of some sort, however I could see nothing inside except a hole in the "barrel" of the tap which I thought would have taken such a screw.
Can anyone advise me how to remove this lever so that I can look at the washers please?
Thank you
keego, thank you for that, I have just looked and it seems that there may well have been an allen screw or something because I think that I can see a thread, but nothing more!
I have browsed the web to see if I can find the construction of this tap so that I know what I am looking for, but no luck...thanks.
If the allen screw has been removed, try pouring boiling water over it and tap it from underneath with a plastic screwdriver handle.
you will see part of the thread some of them screw in quite a way try an allen key (the right size of course)
Thank you all, I will try suggestion on Tuesday - not at home for a couple of days, and my wife won't touch it?
thanks again
