Removed a radiator and now no radiators will heat up
31 Jul 2010
Newcastle upon Tyne
Hi all,
I'll try to explain but i'm not all DYI trained :oops: so i'l do my best.
Husband has removed a radiator in the living room from under the back window as we are having some french doors fitted. He drained the system, turned the water off took the radiator off and then placed two stop ends on the pipes that were leading down the wall (flow and return pipe) to the radiator which was removed. Turned water back on from the stop tap, bled radiators then turned the heating on to see if everything is ok but none of the radiators in the house will come on.
What has he done wrong?
I knew I should have got a plumber :(
I'l try to explain what type of system it is as I don't know the correct terminology.
Boiler in the kitchen heats a large tank in the attic??? I know that sounds dim but not sure how else to explain.
I can tell you it's NOT a combi boiler.....
What can he do to sort the air lock out?
You wouldn't believe he's a friggin builder :rolleyes:
i would cause none have a clue about central heating systems. ;)
is your pump in the airing cupboard with your copper hot water cylinder ?
when you switch the system back on is the boiler firing up for a few mins then shutting down ? or tripping the overheat stat ?
The tank is in the attic not in the air cupboard (it used to be in the airing cupboard but it was moved to the attic when I had a boiler replaced) from the airing cupboard two copper pipes together go up into the attic (they are getting hot very hot - think they're the pipes from the boiler leading up to the tank) then another pipe at the back of the airing cupboard which is getting warm but not overly hot. The water was extremely hot so I ran it all off.
The boiler is coming straight on but then after been on for about 30 mins it shuts down.
where is the pump ?
is it a fully pumped system ?
do you see any of these type of valves maybe near the pump ?
or
what valves are near it ?like this
or
is the pipe hot on eirther side of pump ?
Builders look at plumbers when they are working and think: " No problem, I can do that."
The results are the same as women watching men park, and think: " no problem, I can do that."
