Removed Breakfast Bar. Best Way to Fill In The Gap?
1 Apr 2013
Taking out breakfast bar and pillar to open up the kitchen / diner.
What do I need to fill in the 3" by 72" gap in the floor?
View media item 72205
The existing laminate and vinyl flooring is being replaced with one continuous vinyl.
There is also a gap in the wall. Is it OK to just fill it in with a piece of plasterboard and decorate it? It's not going to be seen as new worktop and appliance will be covering it.
View media item 72206
What is the sub floor - its difficult to tell? I would be tempted to just use an appropriately sized fillet of wood hammered in flush, then use an underlay to smooth out any slight imperfections in the floor surface, followed by the vinyl
Here's a close up picture
View media item 72208
The layers are:
Concrete base
Blue polythene
Pink insulation
Wood
Is underlay necessary? The new vinyl is Tarkett Goliath, which is 4.5mm
So just fill in the gap with closest fitting size wood. Then fill in any edge gaps with filler. Dry, sand it smooth ensuring same level as surrounding area.
Hi, re your latest pic. In that case I would line with polythene, fit an offcut of rigid insulation (to avoid a cold spot on the floor), then wood fillet, sand level to match surrounding flooring. If the vinyl is cishioned, you shouldn't in theory need underlay, but I would be tempted to use some to smooth out any imperfections, though I guess it depends if you are glueing the vinyl down. I would probably take advice from the supplier in that case.
Thanks. Now complete.
I filled in the big gap with the recylcing the wood from the breakfast bar frame. Filled in the small side gaps / top with woodfiller and sanded. Seems good enough.
