Hi
I have typical radiators in my house.
Whoever fitted the radiators mangled the compression nuts on all of the connections between the lockshields / trvs to the copper pipe. It looks as if they were tightened up using a set of badly fitting mole grips ??
When decorating I decided to replace the LS and the TRVs on several of the radiators.
I used an olive puller to carefully remove the brass olives from each of the 15mm copper pipes.
I noted that there is an indent around the copper pipe where the olives were located.
I appreciate that the olives have to tighten down on the copper pipe in order to create the water tight fit.
What I am wondering is whether the new LS and TRVs will tighten down on the existing pipe and create a water tight seal.
I was thinking about applying some Fernox LSX around the indent in the copper which would under the new olives as a belt and braces approach.
What I am wondering is whether to try this approach ( which might sound like a bodge ) or whether to cut into plasterboard wall and replace the length of 15mm copper pipe with new.
I would be interested in everyone's experience on this matter.
Many thanks in advance.
