removed tiles from bathroom wall
10 Jan 2007
ive removed tiles from my bathroom walls , problem ive got is making good of walls , walls are covered in tile adhesive with notch trowel pattern
what options are open to me
could i reskim walls , when walls are re tiled will there be secure on skim
could i plaster board over walls
could i apply a coat of bonding
ever help would be apperiated
Scrape it off with an angle headed scraper.
Stay Clean
It is a yes to all three of your questions. Which one you choose depends on lots of factors, the easiest, the cheapest, the best finish, the size of the room, the use........
The easiest - is to pay a plasters to do the job you end up with a lovely surface for tiling.
The cheapest - probably Dot n Dab.
