Hi folks,
I am currently turning my toilet into an office (toilets are such optional items ), anyway, I've pulled the pan clear of the waste pipe which was easy enough but now I'm stuck.
Basically I have a 160mm cast iron waste sticking out of the floor which I plan to cap and box. The cap I've chosen is this one: http://www.toolstation.com/shop/Str...Flexible+End+Cap+155+165mm/d210/sd2849/p78470
First of all is this the correct cap?
Also secondly and more importantly I have put a plastic bag over the waste pipe for the time being but noticed the bag "burped" when the upstairs flushed the loo.
Now I know that soil stacks are supposed to have a vent at the top of them but this soil pipe comes down through the house internally and I was unaware it was connected to anything other than our loo and bathroom sink. I don't want to create a vacuum by capping off the sink and loo wastes, was the "burp" just because all pipes go to a common drain and is there any way to know if the pipe is properly vented? Perhaps the pipe was vented through the sink or toilet, but I don't see how as surely both have a trap which has water to stop air and stink coming up?
Thanks in advance!
Pictures!
Little extra info the house has 3 floors, a ground (which is where the toilet in question is), an upper flat and a basement flat. The picture of the soil pipe is in the basement flat in a utility room. The toilet that I have removed is just on a normal wooden floor boarded floor.
(Cast Iron toilet waste 160mm)
(Internal Soil, I think the chunky side goes to the bog and the small side goes to the sink, about to check that though)
Thanks in advance!
Pictures!
