Hi Chaps. My property has a chimney that is part removed on the ground floor. I need to fully remove the Chimney to make BC happy.
The Chimney is in the part of that roof that is original house and does not have any felt. I have a plan for later in the year when the weather is better to felt this part of the roof and also replace sofits etc.
What I would like to do is start on removing the chimney now. I am thinking about removing the tiles from around the chimney from the loft then removing the chimney to ceiling level and doing a temporary repair on the hole.
Just wanted to know peoples thoughts on this? I realise I should do it properly and fork out for Scaffold but if I can put that money to good use somewhere else I would like to.
Any ideas on patching the hole would be good too. I was going to try a piece of board covered in a tarp and pass the tarp under the tiles to let the rain run off.
