Hello all
Last night, I removed a radiator from my kitchen, since it is going to make room for some kitchen units.
I intend to put in an under cabinet central heating kickboard radiator at some point, so wanted to keep the feed and return pipes and the valves as they were.
So, I used a decorators cap to close off the TRV valve (cap has replaced the trv) and closed the lockshield valve also and then removed the radiator and its tails. All went well, except that I needed to use a bit of force to remove the nut on the TRV side. I think this unsettled the seal between the pipe and the trv valve, since I now have a very slight leakage from the underside of the valve. The pipe is 10mm Kuterlex.
So, I'd appreciate any advice on what to do now. I tried to tighten the valve nut, but it seems to be fast and I'm concerned that any further force might make things worse. It seems that the whole valve just rotates around the pipe, rather than tightens up.
I'm not sure whether I can slacken off the nut around the 10mm Kuterlex to see if I can reposition it. ie do I need to drain the system down before I can either reposition the nut or cap off some other way.
I'm also not to sure how to cap off 10mm Kuterlex - if it became easier to just remove the valve and cap off until we have the kickboard radiator to install.
Any help or insight appreciated.
Many thanks
Brian
Many thanks
Brian
