Hi, i've just moved into an apartment with a storage heater in the hallway. The make of the heater is a Heatstore HSXDA12N. I would like to remove the heater from the wall because it's not needed and possibly change the wall socket where you switch it on into a plug socket, otherwise totally remove it all and just plaster the wall.
I wanted to know if removing the heater was something i could do myself or would i need to get an expert in to come and remove it?
Also, if i did want to change the switch into a plug socket, would this be possible and would this be something i could do myself in terms of re-wiring the socket, or would an electrician need to do this? This may sound a bit daft but if i was not putting a plug socket in, could i just trim back the wires, tape the ends and plaster them into the wall?
Any help much appreciated!! thanks!
