I moved into a house last year that has a wired alarm system fitted.
I need to permanently disable it so that I can do some building works involving removal of sensors and wiring. I do not want to set off any anti-tamper alarms.
If I switch off at the mains and just allow the backup battery to run down will this set off the siren at the box which I guess has its own backup battery?
If allowing the main battery to run down does not set off the siren will I be able to open the control box to remove its battery without the anti-tamper going off? ie is the anti-tamper wiring routed through the control box or is it a direct circuit to the siren?
Keith
Keith
