Firstly - hopefully this doesn't count as DIY gas work as I'm talking about a fire running off a propane cylinder rather than mains gas?
Anyway, we bought this house that has an LPG 'coal effect' fireplace hooked up to a propane cylinder outside the back door. The cylinder seems to be empty and it doesn't look like the fire has been used for quite some time.
We'd like to remove it, but I'm aware that LPG is heavier than air, so if I go ahead and disconnect the cylinder and/or fire, there's likely to still be LPG sitting in the pipe between the two.
What's the best way to go about disconnecting and getting the gas out of the pipe so that can be removed?
