We live in a house built in the late 50's, early 60's.
I am currently working in the bathroom, which I made slightly larger a while ago by removing the clinker breezeblock wall that ran between the toilet and old bathroom. This wall was built directly onto a floorboard, and across the ceiling joists below, without any other form of support. Running parallel with the ceiling joists in the attic, and finishing between two of these, made it a relatively straight forward process to remove this wall.
My concern lies not with this removed wall, but with the other internal wall that formed the old bathroom. This wall is also built in clinker breezeblock, and was originally built onto a small timber plate, over a fairly substantial timber joist below (approximately 8" x 4"). Below this joist lies the kitchen, but no support, just as the first wall was constructed. However, in this case, there are ceiling joists running across the top, and resting on, in the attic space. The house was not built with any framework in the roof, it is just roof rafters supported on either side by substantial cross beams, with joists running from rafter end to rafter end.
I recently called upon the services of an electrical company to completely rewire a new shower installation I am making. Part of this work entailed fitting a wall switch for this shower on the outside bathroom face of this above mentioned wall. The guy carrying this work out was rather heavy handed and caused much damage to the joints of about six of the breezeblocks, as far as I can make out that is. So heavy handed was he that his mate actually asked me to fit a timber backing plate to the wall on the bathroom side, so that they could fit the switch pattress to something.
Having voiced my extreme concerns to this electrical company in no uncertain terms, I am now worried about the wall.
My thinking is that I must remove this structure and replace it with a new timber stud alternative. I have all the materials, and really keen to set to with the job. But I am concerned that there could be problems regarding the joists above.
Any help would be gratefully received thank you.
