Hi, I need to remove asbestos roof shingles from a ground floor level bay roof and was hoping someone here could give me some advice as to how best to go about it. I'm aware of the dangers of removing asbestos and will get appropriate protective equipment.
I have read through other posts and I understand I should use a 'slate ripper' to remove the nails so that the tiles can be removed whole. Is this the best way or should I approach the nails from the head of the nail; if so what tool should I use. I have found a slate ripper for around £15 on ebay; is it worth getting this or would I be better off hiring one?
I believe the roof is original- the house was built in 1929. Are the nails used likely to be copper/ easy to remove?
