I am fitting a new handle and lock to a door. The holes do not line up with the previous handle so I am having to drill new ones for the brass screws.
The drill is only about 2-3mm so I am using a hand drill. Drilled first one OK. Second one the drill was slipping, so I tried to tighten the chuck while the bit was in the door. Disaster. Bit broke flush with the door.
How do I get the broken bit out of the door?
