removing cold water tank?
8 Oct 2005
London
My home has a combi boiler, and still has a cold water tank installed in the loft, which supplies the toilet flush and cold taps on bath and washbasin.
I want to take the tank out, partly because it makes a dripping noise for ages after flushing the toilet or running a tap, and also to make the cold tap water in the bathroom drinkable. The extra space in the loft might be useful too.
I am planning to remove the tank, and join the 15mm cold water intake pipe to the 22mm outflow pipe, using a Wickes 3 way speedfit joint [2x22mm, 1 x 15mm] with a 22mm cap, a 15mm stick, bent to a 'u' shape, and speedfit clips.
Any advice or warnings gratefully received.
You mean not being able to flush the toilet or boil a cuppa when the water main bursts and the water is cut off? ;)
I guess I like living dangerously
:LOL:
i'm not understanding why you'd use a reducing tee and block off one of the exits when you could just use a reducing coupler?
Wickes may not stock them but a good plumbers merchant will. Wickes speedfit is just JG speedfit in a different packet.
It was all I could find that would do the job!
Thanks a lot for the info mate.
I'll look for a JG reducing coupler then instead.
So I am right in thinking that this is not the normal setup?
I bought the house from an elderly gentleman called Mr Perfect. He had been very keen on doing hoem improvements with his son - rewiring, double glazing etc - and should have been called Mr Bodgit. I'm guessing he had a hand in the central heating and boiler installation, and decided to save a few pennies by leaving it in place.
I only discovered all these things after buying the house of course :rolleyes:
- homebuyers survey mentioned nothing. I've already had to have most of the house rewired, and the seals have gone on half the double glazing. :mad:
Very unusual, very stupid, and a good reason why professionals should do these jobs.
