So before we start I need to explain that we have tried to find the cause of the damp which we believe to be caused by next door, however even with Surveyors, insurance companies etc involved they completely deny it as it hasn't been too bad we have just ignored it, but now we want to decorate our bathroom so it needs sorting out.
Firstly the issue is odd, the damp is about half a metre square in the middle of the wall. An independent damp expert believes that it may be caused by excess salts in the brickwork caused by animals being kept in the barn that was converted, specifically horses, not sure where the moisture is coming from (I still think next door) but as it is a bathroom on both sides it could just be moisture in the air. The wall is not damp above, below to the left or right of this area!
So I am ready to remove the damaged damp plaster. what should I do to replace. I was thinking either a waterproof cement render and then skim or attaching a waterproof cement board to the wall and then skimming over. Anything I can put on the bear brickwork prior to the cement render to help or any other suggestions.
I have got to the end of my tether with trying to get next doors input so just want to solve the decorating issue now. I know the underlying cause should be solved but I will leave that for 5 years time when I rip the bathrrom out completely!
Thanks in advance.
Thanks in advance.
