I am trying to install a new towel radiator and as the cavity is too small hide the pipework for increasing the bore of the pipes from 8mm to 15mm to match the radiator valve and mount the valves from the wall, I have decided to pull up small sections of floorboards and do the pipework under the floor so the valves come up through the floor. What would be the easiest way so as not to damage the boards? The wall I am working with has a joist running parallel to it and the joists are spaced a foot apart.
Many thanks!
Many thanks!
