Removing glazing Beads
22 Aug 2006
Carmarthenshire
Trying to remove glazing beads to remove sealed glass unit to access frame fixers, any tips to removing beads without applying excess leaverage pressure on glazed unit.
A narrow 1 inch scraper in the centre of the bead, prise it away from the glass & it should pop out; you will need even more confidence when you have to bash the glazing bead with a rubber mallet to get it back in again! Insert each corner of the bead first, make sure you engage the inner lip & work your way towards the centre of the bead.
Don't worry, you won't damage the glass; it's not as fragile as many people think; as long as you don't stress the edges or hit it with anything hard, you just need that bit of confidence with it!
