Removing ivy tenticles!!!
18 Jul 2006
Hi guys,
I have recently cut down a load of ivy that was growing at both the front and rear of of our house.
No I have a problem in removing the little tentacles that were left behind. I can remove them from the window ledges by using some warm soapy water and a sponge (with lots of elbow grease!).
But does anyone have a solution for removing the tentacles from the brick work? I have tried a metal scraper and just a regular kitchen scourer but both tend to mark the bricks.
Any info would be great!
Damage.
If you leave them for a while to die and go brown they will pull off more easily.
Perhaps it's a male ivy. You can tell because the tenticles are hairy.
It`s not a testicle job if you leave them to wither ....sorry technical :oops:
