removing laminate flooring/ glued to kitchen island
23 May 2009
British Columbia
Help!! I am attempting to remove old laminate flooring from my kitchen, the planks are tongue and grove and not such a trouble to remove...problem is, some planks have been glued to my kitchen island and I can't get the planks off, don't want to hurt the island...any ideas would be hugely appreciated!!!
I think the island is in fact on top of the laminate??? oh no! what can I do to get rid of the laminate and not destroy the island???thx
sorry bad grammer should be are you shure the island isnt standing on top off the floor!!!;)
is there any services or fixings going from the island through the laminate into the floor !!!
if there is your choices are
disconnect services support manover the floor out keeping in mind the fixed pipes will be around 9 to 18mm too long on reconection dependant on floor /underlay thickness
cut the laminate at the island base and use a moulding [possibly with a slot/rebate ]to cover the exposed edges and the gap
Thanks! there are no services, pipes etc. running thru the island, just that bloody floor:) what kind of saw would work? what would I ask for at the store? thx
what size is the island and what worktop is used [would it move easily]!!!
what flooring is underneath!!!
