Removing lead flashing
12 Aug 2012
Oxfordshire
I have some lead flashing to remove from some brickwork at the rear of my house. It used to be connected to a wooden lean to that the previous owner removed.
Do I literally just remove the pointing with a chisel, pull out the lead and re-point?
In theory, yes. the books say it is held in by lead wedges, just below the depth of the pointing. However in a Victorian house I had the lead was buried so deep that I chickened out and just cut it off flush. I suppose that one could just dig the pointing out by 1/2" and if the lead does not pull out, cut it off at this depth and repoint.
Frank
Cheers frank
My house is pretty old (1880's) but the extension with the flashing was built in the 60's. I knew I would come across some lead wedges at some point, but judging by the quality of the rest of the building work, I probably won't.
