Removing loft tanks possiblity
4 Oct 2021
Looking for some advice/expertise on the possibilities of removing both the large cold water tank and smaller CH tank.
A couple of years ago the previous owners converted to an unvented cylinder with a expansion tank. I believe the cold water tank has been redundant and empty ever since but left in the loft. However, the CH smaller tank is still operating.
Is it possible to bypass the CH tank and have this piped into its own loop? Allowing us to remove both the tanks?
What are my possibilities and also potential issues by doing this?
Appreciate any advice.
Yes ,it's possible to ammended your c/heating system to a sealed/ pressurised system.
The question arises as to whether or not the increased pressure can be handled by your pipework/ joints/ radiators etc.
Thanks for the replies. Could I just install a pressure regulating valve and set to around 1.5bar where I'll bypass the tank in the loft?
The model of the boiler is a Potterton suprima 40 boiler. Believe this was installed in 1993 but the invented cylinder was upgraded in 2018.
The suprima came with an optional sealed system kit, but there are independent kits available but not really DIY to be honest, you cant just do what you were proposing
Thanks again for the replies!
After checking the excat model of the boiler it's a Potterton profile 40e.
Do you have any suggestions how I can remove the CH small tank from my loft and reasons why the original suggestions wouldn't work and what negative effects this would of had?
Thanks again
Various things need doing to convert to a sealed system, requires an expansion vessel to be fitted ,a safety valve for pressure relief ,a filling loop between cold mains and sealed system ,a pressure gauge ,the removal of f&e tank and various ammendments to pipework, to name a few.
As Ian said ,not really DIY.
