removing nailed in fence panel
25 Jul 2007
Hi there,
What is the best way of removing the nails from a fence panel in order to release it from the posts it is attached to without damaging the panel.
Thanks!
Hacksaw blade in between the panel and post, wedge a screwdriver to prise it apart temporary while cutting although sometime if you take the screwdriver out again the nail head maybe proud so claw hammer to pull it out. A wrecking bar should do it. I have a heavy duty nail puller and do work but a bit over the top for what you want, here
