Hello all.
I'm looking at removing a non load baring wall in my house, typical 4 box affair downstairs (kitchen on the left at the back and lounge on the right at the back) joists run front to back.
The upstairs has three rooms at the back, with one dividing wall above the kitchen and one above the lounge. when I look under the floorboard I can just see the lathes meeting where the ground floor wall will be, therfore baring no load.
I know when removing a load baring wall and supporting above with an RSJ yuo need to leave at least 200mm piller for the steel to rest on, but I'd like to remove it all the way from front to back leaving no pillars. is this possible. It obviously removes some latteral support for both the rear wall and centre cross wall...
Would liek to gain some indication on here to see if i need to get in a structural engineer...
Thanks,
Virgil..
Thanks,
Virgil..
