Removing paint from glazed tiles
3 Jan 2008
Hi there
I've just removed some laminated flooring that was covering the tiles in a fireplace (previous owners loved laminated flooring all over the house) to discover that the original glazed tiles are there. They've been painted with emulsion and what looks a primer, I would like to remove the paint as the tiles look to be in pretty good condition. Is it OK to use a product like Nitromors?
Appreciate any suggestions.
Martin
Nitromors should be fine but try eally hot water first...that might soften the paint allowing you to scrape it off.
I have the same problem as you,MsBridge.Tell me,please, if the hot water worked
I gave up on the hot water too many layers of paint, it took a couple of coats of nitromors and now looks fantastic.
HTH
Martin
