Hi.
I am about to start removing old, thick paint from metal window & window frame fittings. These fittings should allow a window to be lifted up and then swing inwards vertically (like a door opening). The paint looks like old gloss / emulsion & is quite thick in most places. Seems the previous occupants of my flat must have just painted over all the original fittings again & again. So often that now some of the fitting do not work properly: main problem is that paint has accumulated on the 'barrel' (or bolt - I am making up terms here!) and stops the windows going back into their fully closed state (i.e. there is a small gap between the windows & frame on the bottom).
Whatever, that's the background - the question is: whats the best (easiest & cheapest) way to remove this paint? I can take off the fittings easily enough (after scraping any the paint over the screws).
Any help will be appreciated.
Eddie
Eddie
