I'm after some advice on removing a part of a wall that supports an RSJ that supports the 1st floor, floor joists.
My plan diagram below shows the RSJ (Red) and the wall that it sits on, the other end of the RSJ sits into the gable end wall of the house.
We would like to remove the return part of the wall, the part coloured Green.
The Blue line is Paramount board (Plasterboard) that forms the wall between the Kitchen and Dining Room.
Once the plasterboard wall is removed it will leave the 2 brick return (Green) This return is obviously there to give support to the part of the wall that the RSJ sits on.
I'm just wondering if the 2 brick return could be removed then the remaining wall extended over to join the gable end wall of the house.
The wall would be built off the concrete oversite under the timber floor, the RSJ would stay in place with a block wall under it. ?
Thanks.
View media item 57371
Thanks.
