I need to take a radiator off the wall as it is in the way of a new wall. The pipes are fed from the loft space down the wall. Is there away i can cap the 2 pipes in the loft without having to draing down the whole system to do it? I will eventually be replacing the whole central heating system but i little bit at a time room by room over a period of years, and dont want to drain the system down each time hopefully.
I know you can freeze pipes, cut them and cap them but i dont have the kit for this. Is there a fitting that can clamp onto the pipe for example? The pipes are mainly microbore copper.
