Removing programmer / timer dial?
4 Aug 2005
I have a mechanical CH programmer / timer (model: Danfoss SET3M) which has started to make a loud continuous ticking noise. Someone suggested putting a dab of grease on the cogs but I'm not sure how the thing comes apart. I can see a screw underneath the large round dial but I have no idea how the dial comes off. Is there a clip that holds it in place as I have tried pulling but worried that I might break it if I use anymore force?
if its making a noise..that is annoying you, then replace it....its only 40squid. and when you get new one it will show you how to dismantle. if its like the danfoss 103, then no rewiring reqd, just plugs in......i say plug...well slides in...
not done a set 3m, but if it is noisy..grease aint gonna cure it.
they have a row of pin type contacts and can be quite stiff
instructions read
Locate the module on the latches at the bottom of
the wallplate and hinge upwards to fully engage the
unit connectors into the wallplate. Tighten the two
fi xing screws to secure the unit to the wallplate.
http://www.danfoss-randall.co.uk/site/downloads/3562.pdf
so I guess take the screws out and hinge down.
Well hats off to Danfoss. I was going to splash out on a new programmer as I didn't think the old one would still be under warranty and rang danfoss to enquire which programmer would be suitable. They said they still make that model and very kindly sent me one FOC. I just had to send a £30 cheque which they refund when you return the faulty one. I can't fault their customer service. Yes, the SET3M programmer simply slots into the electrical contacts so a very easy straightforward job.
