I have to remove a rad with a trv. Can someone confirm how I ensure the valve is definately turned off so I do not flood when the rad is off (if the temp drops for example). Many thanks.
It depends on TRV make and model.....some have a 0 posiion this is an off position. Some just go back to a frost setting. A cap is a sure way but a lot of TRV dont come with caps now at the 0 position does the same job.
