Removing radiator
8 Sep 2005
Manchester
I'm planning to remove a radiator from my pressurised system. Presumably (after switching off the system and draining) I can just cap off the two copper pipes with suitable compression fittings. At my local DIY place they told me I could just fold the copper pipes over instead of putting on compression fittings - is it easy to do? Does the fold need to be crimped or something?
For info, I'm eventually planning to tile over the capped off pipes. Thanks
Whhhhhhhhhhaaaaaaaaaaaaaaaaaaatttttttttttttttttt!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
fold the pipes over, what a dick head, fit proper compression fittings as you first suggested.
that's so they can sell you the gear to repair the ceiling when it finishes up on the floor :LOL: :LOL: :LOL: :LOL: :LOL:
Thanks for the replies, will use compression fittings. One more question, I had intended to drain the system but read a bit about freezing pipes on this forum, this sounds much easier than draining. Can I do this if the system is closed/pressurised?
If I do go ahead and drain, how do I add inhibitor when I refill?
images
with one of these via a rad ;)
Pressurised system, screw any caps on auto airvents down release the pressure through rad bleed screw when the flow stops system should have created a vacum in it`s self.close bleed You can then cut the pipes one at a time and seal with caps as very little to no water should come out and remember to loosen auto air vent caps when finishe and repressurise
