I need to remove two rads from my combi system so I can knock down a wall in my upstairs bathroom and then get the whole room re-plastered.
I then intend to cut both supply and return speedfit pipes in the loft and put in a loop so that the water will still flow but only to & from the boiler.
Once completed, I'll re-presurise the system up to 1 - 1.5bar at the boiler.
My question is that as I'm likely to introduce a fair bit of air into this circuit while i'm doing the work, will I have to bleed the system, and if so how, or will the boiler take care of it when the central heating finally switches back on sometime in October?.
- The rads are situated half way up, and are on either side of the wall that is getting removed.
- They are highest two rads in the house.
- They are connected in series with feed & return pipes coming from above through the loft.
- The boiler is downstairs in the kitchen.
- The pipework in the bathroom is copper, but once in the loft it reverts to JG Speedfit.
