Hello experts, im removing 1 or 2 rads to decorate (remove n replace wallpaper) for few days so i wanted to know is it ok to run my heating system while they are removed? cos its getting bloomin cold at night now cheers Dave.
as well as making sure the valves are shut properly, if you have TRV's be aware that they have a frost setting on them, which means that if the temp drops too low the valve will weep some water to prevent freezing (thats ok when connected to a rad, not so good when it weeps onto the floor and causes damage) you might need to consider capping the TRV side just in case
