Hi - I need to remove a few radiators to get behind them for decorating.
I've read that you need to be a bit careful where thermostatic valves are concerned - most of mine have the * (frost) setting, but not an off position. Is this a problem? I'm keen to not have to drain down the system.
If this is a problem, I do have some rads in the house with thermostatic valves that do have an off position - can I just temporarily switch the valves to the rads that I want to remove?
Many thanks
Many thanks
