Hi all,
I don't have a clue what I'm doing and wonder if anyone can offer any advice on the following!
I need to replace a rotten fascia on my slate roofed single storey kitchen. I have taken a look, and established that the bottom row of slates are laid at right angles to the others, and nailed to the top of the fascia at each side.
The best option I can think of is to cut through the nails fixing the bottom row of slates (I can get a hacksaw blade into the gap to achieve this), then remove the slates and existing fascia. I assume that I could refit the bottom row of slates using copper tingles fixed to the top of the replacement fascia.
The problem is that I have found a similar thread in which an experienced poster says that the method above isn't possible:
//www.diynot.com/forums/viewtopic.php?t=90414
However, I don't quite understand why it can't be done! Does anyone have any advice/opinions?
Cheers!
Cheers!
