hello guys.
i am going to remove the render at the bottom of the wall as we think water may be staying next to it and causing a problem.
we plan to remove it and replace it with a 'slide effect' to push the water away from the wall, is that possible to do with render?
also around the outside bottom of our garage (also rendered) there is this material that we think is also there to push the water away from the wall and into the ground what could this be? can you still get hold of it?
those bags of already mixed render with lime, can they be used?
are there any other ways of a 'slide effect' to push the rain water away from the walls?
thanks in advance
shezzar
thanks in advance
shezzar
