Hi All,
I need some urgent advice if possible please!
18 months ago I had my old plinth removed and replaced as it was crumbling away in many parts. The main wall at the time projected further out than the plinth which I believe was the correct way to do it. The new plinth was put on but this time brought out to be flush with the wall, which I was disappointed with and a little concerned.
However after approx nine months it became obvious that the mix used for the plinth must have been wrong as the rendering started crumbling and falling off with just the merest contact with it. I contacted the original contractor who after agreeing to replace it some time ago has finally started today. After starting to remove the plinth he is now saying that the brickwork is in pretty poor condition in many places and would need remedying before being able to put on a"Scratch Coat" and re-render the plinth. (I don't understand why this would be the case now when it was never mentioned when he removed and replaced the original plinth 18 months previous). What really worries me though is that he now intends to use a powerful Jet Washer to clean off the brick work (ie from just above the DPC to ground level before carrying on with the new plinth.
SURELY that cannot be right to use a High pressure washer around and below the DPC? If anything I would have thought using an air hose might at least be more appropriate, if not a simple dry hand brush.
Please help if you can before possible serious damage may be caused!!
