You can put pictures into your post by "copy and paste" or "drag and drop" or "attach a file"
Hi there,
First post as I normally what I need on here after a google search.
I’m having an issue with the slow draining shower and I’m a bit reluctant to just keep pouring down the unblocker liquid so would like to rod it (with the flexible snake type).
The problem I’m having is removing the inner part of the trap so that the connection to the waste pipe is accessible to rod.
The drain cover is either stuck fast or not supposed to move and I’m reluctant to force it in case I’m not supposed to an it effects the seal.
A couple of photos below - the cap just lifts off so it the chrome surround in the photo I’m not sure if I’m suppose to be able to unscrew / lift out?
Any help much appreciated!
https://ibb.co/jGfw7Sf
https://ibb.co/m4NWqGb
