Is anybody able to advise on cutting off the water supply to sink taps?
I am redoing our downstairs toilet/utility room and have installed a new sink/taps in a different location (using the old washing machine supply).
I now want to remove the old sink so need to shut off the water supply to the hot and cold taps here. Pipework is all plastic (polyplumb I believe) and the floor is tiled so I can’t disconnect the pipes. I was thinking of cutting the pipes short, using some polyplumb socket ends (http://www.screwfix.com/p/polyplumb-socket-ends-15mm-pack-of-2/31175) then boxing the pipes in at the skirting board level. I obviously don’t want to use anything that is unreliable though and that might burst off so would like to know if these will be ok? Or is there a better option … e.g. would I be better to fit a compression stop end? Or an isolation valve then a stop end on each pipe?
Thanks in advance,
Jamie
Thanks in advance,
Jamie
