Removing some tiles without damaging the others around it
1 Aug 2004
Hi all,
Just had bathroom and shower plumbed in while i was away, im redoing the tilework myself so could someone please advice me to how i remove the 5 broken tiles in the area shown so i can add the new size tiles.
Cheers
Thanks for looking
Clubb699
depends on how well they are fixed,you may be able to lift them with a wallpaper scraper and hammer.
I would sugest:
Carefully scrape away the existing grouting that connects to a tile you want to keep, you can do this with a grout scraper.
That done then you can try lifting the broken tiles, you should now have a 2mm ish gap to others so it should not affect them.
If needs be you can drill/smash them carefully to aid removal.
As said, a scraper or bolster chisel used as a lever can aid removal.
It may be an idea to mask off the good tiles with heavy duty tape & thick cardboard (or even cereal boxes) to protect them while doing this.
Those 2 holes in the tiles can perhaps be filled by adding fancy hooks for shower gel & a loofah etc :D
The main worry would be destroying the plasterboard as you try to remove them!!!!
Roughcaster.
Hi lads,
Thanks alot for the great tips there much appricated i will take my time and see what i can do ;)
Clubb699
a massive lump hammer and start again!
the plasterboard is gonna come with it and then your f******d
Thats another thread "How to repair big holes in plasterboard" :D
