I need to re-seat the taps on my bath because when the shower sprays them, they leak through the hole and drip down. No problems at all with the pipes to the taps leaking.
I did the cold without any problems - it's on the "outside" and I could get a grip on the plastic nut with a plier (think it might be called a water pump plier?) and that loosened and did back up nicely.
However the hot is really inaccessible behind the overflow and because of the wall. A box spanner looks like it would do the job - but not with the pipe still connected.
Is there any way of doing this without removing the pipe? (Reattaching it in the small space would be a nightmare - plumbers must be very nimble.)
Thanks!
-Mark
Thanks!
-Mark
