Removing the permenantly on radiator
1 Sep 2007
Sussex
On my (pressurised) CH system, I currently have one radiator that cannot be turned off. All the others have TRVs on them. The chap that fitted it said it had to be like that so that the pump would never be trying to pump a closed system.
However, soon I will be removing that radiator when I'm extending the kitchen.
I realise that I have to have a path so is there a shunt or bypass that I can get to go in place of that rad ?
I understand that normally the bathroom rad would be permenantly on, but the new bathroom has a towel rail and of the valves I fitted, neither are lockshields (the downside of letting SWMBO choose flashy chrome head jobbies) so I cannot guarantee someone will not turn them off.
the rad with no TRV is usually the one in the same room as the room thermostat if that helps
not really, when he fitted it he bypassed the room stat (which was on the middle landing - no rad there).
I would ask him, but I'd need a oija board..
He said something about it not being used anymore, when the heating is on it's just on and the TRVs control temperature.
It all worked ok after he did it.
oh dear
he shouldnt have done that, and because he has you MUST have that bypass rad
oh dear
Oh balls.
So, back to the original question, can I fit a shunt or somesuch in place of the rad ?
Will you be putting a radiator in the (extended) kitchen?
If yes, all you need is a temporary fix. Put one of the TRVs on full blast, and tell everyone in the house not to turn it down! Put a sign on it or something if you need to. Then, when you put a rad in the new kitchen, put a lockshield on it. Sorted.
If no rad in the new kitchen, just swap one of the TRVs for a lockshield, anywhere in the system will do. Maybe on the landing, or get the Mrs to choose a pair of fancy chrome lockshields for the bathroom.
Cheers.
I'm going to rebalance the system as I've changed a couple of rads, so does the permenantly on rad need to be fully open, or should I balance it same as the others ?
