Removing uPVC doors
25 Aug 2006
I need to temporarily remove external upvc doors so that I can get furniture in and out. How is this done? Do the doors just lift off the hinges or do I have to adjust the hinges in some way first?
If it helps the doors were made and installed by Interglaze in the Northwest but they have now gone out of business.
heeellloooo Patrician and welcome:D:D:D:D
carefully remove the plastic cover over the hinge
you will normaly have some form of adjustment and securing screws
put something under the door to fully support it [centraly or full length]
start at the bottom hinge decide whether your screws need to be fully removed to remove the door [have they got a full length slot in front of them]
repeat second hinge keeping in mind handling the door wrongly could dammage the top hinge
it may of course be completly different where someone else will help you ;)
Hi big all,
Thanks for the speedy response.
Just to make sure I understand what you are suggesting;
The hinges on my doors have a tubular part on the door frame with a plastic cover under which there is a metal insert about a cm diameter with an allen key slot. This can be unscrewed and the metal insert (about 5mm deep) can be removed.
The door part of the hinge is a box shape with an allen key slot facing the frame. Is this the securing screw you referred to?
Could you clarify which are the screws which you suggest might need to be removed and where is the "full length slot" as I can't see one?
Patrician
the ones i have worked on have between 2 and 4 screws on each hinge that tighten into the door
with an adjustment allen screw running parralel to the door side
the way you remove them is by removing the screws full then seperating the hinge from the door
somtimes one part remains on the door and you only have 1 or 2 securing screws to hold them together
you shouldnt normal have to touch a screw going parralel to the door to release it as these are normaly the adjustment srews
if there are no obviouse screws to release the door experiment on the centre hinge to work out how to release them
or wait for other ideas ;)
just a quick reply had to take off the mother inlaws upvc door off the other day just lifted it and it came off worth a try before un screwing hinges :idea: :)
could be easier to remove glass from window in room where stuff is bein moved from?
A picture or link to the hinge type would help. Most common hinges have pins top and bottom that need top come out in order to seperate the door/frame hinge sections. These pins are held in place by grub screws.
